Old 05-06-2007, 05:22 AM
Captain Avgas Captain Avgas is offline
Default Float sensors in tip tanks
I'm thinking about the possibility of installing the standard Vans supplied Stewart Warner float type sensors in my tip tanks as a way of ensuring that fuel is being transferred from the tip tanks to the main tanks.
However the tips will not have any fuel in them on most occasions and it occurs to me that the Stewart Warner type sensors may not like sitting in air for maybe months on end....ie they may corrode and become unserviceable.
Does anyone have any thoughts on this.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 05-06-2007, 06:32 AM
donahuedc donahuedc is offline
Can't you just look at the gauges on the mains to see that they are getting fuller?
Old 05-06-2007, 09:45 AM
az_gila's Avatar
az_gila az_gila is offline
Post Should be OK...
Bob.. should not really be a problem.
When the same sender are used in cars they are often intalled on the top side of the tank. In this location they will be "dry" much more often than wet.
Even cars that have been left standing for a long while usually have functional fuel senders when "re-activiated".
I've only changed one auto fuel sender on my old cars, and it was because of sticking, not corrosion, and that Dodge van sender was mounted half way down the side of the tank.... YMMV
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-06-2007, 10:43 PM
There's a logistical problem with that owing to the fact that the main tank float sensors don't register the top 20 litres or so of fuel.
Bob Barrow
RV7A
