Old 09-18-2019, 11:55 AM
lr172 lr172 is offline
Originally Posted by rvsxer View Post
Every exhaust leak I've seen showed as a white or light tan coating. If it's black you are too rich at idle.
Good point. I have only had exhaust leaks on my high performance engines and they run much richer than most.
Larry
Old 09-19-2019, 11:26 PM
riobison riobison is offline
Not necessarily true. If the crack is between the exhaust valve and the exhaust manifold, a compression check will not reveal a crack/leak in that area. We found that this past week on our #2 cylinder on our Warrior. It compression tested at 76lbs, but a cracked cylinder in the exhaust port was found.
I agree, I was pulling high 60's on my O-360 so technically a pass. But it still didn't feel right when running. So, I sprayed soapy water around the head and sure enough I had bubbles. Pulled the jug and found a crack between the bottom plug and exhaust valve.
Old 09-21-2019, 03:26 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Originally Posted by fl-mike View Post
what color is your baffle material?
If I remember it was black
Old 09-23-2019, 11:25 AM
theduff theduff is offline
Default Exhaust Leak
I?ve seen this strange orange color many times before. You have an exhaust leak at a minimum but looking around the sparkplug I suspect you may have a cracked head as well.😕
Old 09-30-2019, 01:39 PM
avrojockey's Avatar
Well...it doesn't give me a good feeling so the airplane has come off purchase list. Too many other great airplanes to even consider.
