Old 09-17-2019, 12:05 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Default Is this an Exhaust Leak?
O-320-A1A EXHAUST PICTURE
Referencing linked picture above...What say ye concerning the rust color on the head near the exhaust flange and around the plug well?
It looks to me like a exhaust leak but isn't the typical white color. The other thing I notice is the flange studs...doesn't look like those nuts have come off in awhile which means the exhaust hasn't been removed for inspection.
Old 09-17-2019, 12:32 PM
airguy's Avatar
airguy airguy is offline
Possible crack in the head between the exhaust port and spark plug hole?
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 09-17-2019, 01:43 PM
xblueh2o xblueh2o is offline
Easy enough to test. Pull the plug and do a compression check.
If it is a leak/crack it will show itself instantly.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 09-17-2019, 01:47 PM
lr172 lr172 is offline
Typical signs of exhaust leak are a matte, dark black staining/coating. Rust is something different.
Old 09-17-2019, 06:45 PM
fl-mike's Avatar
fl-mike fl-mike is offline
What is above the cylinder in that area?
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 09-17-2019, 08:40 PM
Ash Ash is offline
Not necessarily true. If the crack is between the exhaust valve and the exhaust manifold, a compression check will not reveal a crack/leak in that area. We found that this past week on our #2 cylinder on our Warrior. It compression tested at 76lbs, but a cracked cylinder in the exhaust port was found.
Old 09-18-2019, 07:41 AM
rvsxer rvsxer is offline
Every exhaust leak I've seen showed as a white or light tan coating. If it's black you are too rich at idle.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 09-18-2019, 10:09 AM
avrojockey's Avatar
There's nothing mounted on or above the head that would be causing the discoloration.
Old 09-18-2019, 10:23 AM
snopercod's Avatar
The source of those rust-colored deposits has to be steel, so that pretty much narrows down the source. If it were my plane, I would suspect that exhaust gasket first. Good luck breaking that exhaust nut free
(2020 dues paid)
Old 09-18-2019, 11:39 AM
fl-mike's Avatar
what color is your baffle material?
Mike W
Venice, FL
N164WM
