Old 05-05-2007, 08:12 AM
ccarter's Avatar
ccarter ccarter is offline
Default F-779 Tail Wheel Spring Cut Out
Any RV-7 QB guys care to share their experience on how they "Removed the Shaded Area" on the F-779? (DWG-27). It is necessary per Van's drawings to properly mount the tail wheel assembly? I thought I could measure and draw it out from the outside underneath the elevated tail cone and go at it with my cut-off wheel while laying on my back...
Old 05-05-2007, 09:00 AM
yakdriver yakdriver is offline
That's how I did mine. Use the template on the plans. I think I had to enlarge it a bit from that but it is a good starting point. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 05-05-2007, 03:02 PM
java's Avatar
java java is offline
Default Make a template.
I made a photocopy of the scale section of the drawing, and then punched holes on the lines of the copy. I then taped the template to the skin, and could shuffle it this way and that to get it in the right place, and used a fine point sharpie through the holes to transfer the patter to the aluminum. Cutoff wheel used for the rough cut, and a dremel bit and emory cloth to fine tune the fit and clean it up. You'll probably have to enlarge it in certain places for the best fit, which is a relatively easy iterative process.
Good luck.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 05-06-2007, 05:26 PM
phil9diesel phil9diesel is offline
Default aluminum cutout
Draw your hole with a sharpie felt pen. Cut out an undersized hole. Chuck a carbide bit and rough finish. File and sand. Done.
