Old 09-06-2019, 06:11 AM
Desert Rat Desert Rat is offline
Default question re; moving wings
Hey guys- I just bought a used rv7 wing & empennage kit. Been looking for a while, and turns out this one was only about 5 miles from my house.
The wings are pretty much done with the exception of a skin on one which is clecoed on. The are currently standing up in a sling style rack that's fine for the garage, but not sturdy enough for transport.
Does anybody see a problem with just removing the one skin, wrapping these in moving blankets burrito style and laying them flat on the floor of a box trailer for the short drive?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 09-06-2019, 06:52 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Wings need cushioning
I moved my completed wings, one at a time, 250 miles, laid down flat on a box trailer BUT I put a 4 inch thick foam bed mattress underneath first. Also used padded removalist blankets over and under, and it was all strapped down. There was no damage at all.
A box trailer will most likely have harsh leaf springs and no shock absorbers, so one or two bumps could cause unnecessary damage, even over a short distance. So I suggest a bit thicker cushioning and make sure there is absolutely no chance of any metal-metal contact. I agree with removing the clecoed skins for transport so the clecoes don't get bent over.
Paul.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
Old 09-06-2019, 09:36 AM
mturnerb mturnerb is offline
I moved mine in the wing rack (home to airport about 20 miles) strapped securely to the side of the big box truck I rented, with lots of padding and some other stuff in the same truck. But I've also moved them (home to storage unit) lying flat on the floor of the truck - but only one at a time as the chord is such that you'll have hard time laying them side-by-side and you'll need a really long truck to put them end-to-end. (Wheel wells in truck limit side-side space).
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 09-06-2019, 10:11 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
5 mile trip - he can easily do two trips...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-06-2019, 04:35 PM
Hey all, thanks for the feedback.
Terry Shortt
Fuselage in process
#72651
Old 09-06-2019, 05:12 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
The advice I got, and easily moved two sets of wings 2,000 miles each, was to put the wings vertically, leading edge down. Under the leading edges I had a couple of layers of insulating foam, the kind with foil on one side.
Leading edges are really, really stout compared to the rest of the wing for moving...
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 09-06-2019, 05:57 PM
Jpm757 Jpm757 is offline
Leading edge down in an 8' pickup bed with plenty of padding.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 09-06-2019, 07:04 PM
I used the wing cradle on casters for the move....50 miles in a U-Haul box van. Ratchet straps to secure the cradle to van's interior, pad liberally with moving blankets. Don't overthink it.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 09-07-2019, 01:24 AM
Robin8er Robin8er is offline
I moved my wings the way you described. I used pillows over the top with a ratchet strap that was tight enough to prevent moving, but lose enough to prevent damage. Snug, but not tight. It worked fine.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
