Old 09-02-2019, 08:57 PM
sglynn's Avatar
sglynn sglynn is offline
Default Blown Starter Fuse
What would cause a starter fuse to blow? It is 7.5 amps in the Advanced Control Module used with a Quick Build panel. It is the older model before they went to logical breakers. I flew yesterday, no problem. But today it wouldn't turn over. Turns out the starter fuse was blown. But why? I examined it and it looks kind of cheap and flimsy. I put in a new one and everything is working fine. Would excessive cranking to start a hot fuel injected engine blow the fuse? Does 7.5 amps sound right for the starter motor? I was thinking it would be a 10 or 20 amp fuse. What else might cause the fuse to blow. I have only 38 hours on the airplane, RV-7A. Thanks
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
www.mykitlog.com/sglynn
Old 09-02-2019, 09:01 PM
The starter motor draws a huge current. The fuse in question most likely is for the starter solenoid (relay), and no, it should not blow from excessive cranking.
Old 09-02-2019, 09:12 PM
sglynn's Avatar
Default starter contactor fuse
Bob
Thanks for your quick reply. Yes, I pulled the manual just now, it is the starter contactor fuse. That's interesting to think about. What would cause it to blow? Could it just be an old weak fuse?
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
Old 09-02-2019, 09:23 PM
Mich48041 Mich48041 is offline
It could just be an old weak fuse. A bad fuse holder connection can generate heat which will blow a fuse.
Joe Gores
RV-12 Flying
Old 09-03-2019, 02:22 AM
Yen Yen is offline
I seem to remember that when the voltage drops in a circuit, the amperage goes up.
You hit the starter and the volts drop way down because the battery is not 100% charged, that may cause the amperage of the starter solenoid circuit to rise enough to blow the fuse.
Replace the fuse, charge the battery and it may be fixed.
Old 09-03-2019, 09:35 AM
sglynn's Avatar
Yen
interesting idea, because just before this happened I was running the panel and lights for awhile with the engine off. I was loading new database and trouble shooting a tail light that burned out. So I may have run down the battery just before trying to start it. Fuse is changed. I'll see how it goes.
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
Old 09-03-2019, 12:17 PM
This may be true some times, but for a dc relay, no.
Old 09-04-2019, 12:19 PM
gasman gasman is offline
OHM'S LAW only applies sometimes??......
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 09-04-2019, 01:46 PM
There are lots of non-ohms law machines. e.g., motors often rely on induction to limit the current. If the voltage is low and the motor fails to turn, it can draw a large current.
Old 09-04-2019, 02:19 PM
snopercod's Avatar
You should have a kickback diode or MOV between the contactor coil and ground to quench the voltage spike produced when the coil is de-energized.
(2020 dues paid)
