Old 05-03-2007, 07:16 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default Painting over powdercoat
I tried painting my canopy frame flat black with automotive spray paint (spray can) and it scrapes off very easily. i had sanded the frame until all the shine was gone then cleaned it with laquer thinner to get rid of any grease then sprayed. Looks good but it will be too easily damaged. Any ideas short of powder coating it again?
Old 05-03-2007, 07:29 PM
skidmk skidmk is offline
I Andrew,, I had done this myself with auto yellow. Was very durable and only finally came off when I soaked everything is thinner. I'm going back to the Van's off white to match my Harvard 2 paint scheme.
see ya Saturday
Mike Bourget
Ottawa, Ontario
Old 05-03-2007, 08:27 PM
az_gila's Avatar
az_gila az_gila is offline
Question Epoxy primer
Sanding and an epoxy primer for a mechnical grip might be the way to go before the finish coat...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-04-2007, 12:57 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
I painted all my interior powder coated parts (sticks, rudder pedals, flap tube, canopy latch rod, etc) by scuff sanding with 120, cleaning with acetone and shooting 2 coats of S-W polyurethane. Absolutely bulletproof after 3+ years.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
