Old 09-01-2019, 02:18 PM
nippaero's Avatar
nippaero nippaero is offline
Question Connector wrap?
What is the orange tape that Aircraft Spruce uses to protect the wire bundle as it exits the connector? I would like to get some.
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 09-01-2019, 02:32 PM
bcondrey bcondrey is offline
Probably Rescue Tape. You can find it from numerous places including ACS and probably also locally for much less money.
Bob
RV-10 builder x2
RV-14 under construction
EAA Tech Counselor
Aviation Nation (RV-12 teen build) mentor
Old 09-01-2019, 02:37 PM
nippaero's Avatar
I've been using Tommy Tape Miracle Wrap which is a silicon tape.
https://www.tommytape.com/miracle-wrap/
I was just curious if there was something the pros use that is better.
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 09-01-2019, 02:38 PM
Rick_A's Avatar
Rick_A Rick_A is online now
Default Silicone tape
I think it is different then Rescue tape. This is the stuff that Spruce sells.
https://www.aircraftspruce.com/catal...es/uniwrap.php
I is very useful for chafe protection and it works well FWF.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 09-01-2019, 02:55 PM
Flyhud's Avatar
Flyhud Flyhud is offline
I’ve used this, available on the aviation supply aisle at Home Depot.
https://www.homedepot.com/p/Nashua-T...3519/204002500
A&P/IA/ATP
RV-4/160hp/O-320/CS/G3X
Old 09-01-2019, 04:26 PM
wirejock's Avatar
wirejock wirejock is offline
Default F-1 tape
Check Amazon too. F-1 Self Fusing Silicone Tape.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 09-01-2019, 04:59 PM
Pretty sure these are all variants of the same basic product - self fusing silicone tape. First time I discovered it, it was the Rescue Tape product. It?s now widely available under different labels.
Bob
RV-10 builder x2
EAA Tech Counselor
Old 09-01-2019, 10:26 PM
Scott Hersha Scott Hersha is offline
Yep. Silicone, self fusing tape. You can get it at Home Depot, Lowes, Menards, Ace, etc.......
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 09-02-2019, 07:57 AM
Walt's Avatar
Walt Walt is offline
I don't think the "rescue tape" meets a Mil spec like the one Rick linked to in post #4 which is what I use.
I know from using both they are not the same product.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 09-02-2019, 09:29 AM
rocketman1988 rocketman1988 is offline
Default Comparison
A data point...
I have used Bothe the ACS mil spec tape and rescue tape.
My observations:
They both self fuse.
The mil spec tape seems to fuse better, IMO. When trying removing it, it definitely seems to be one solid mass. When removing rescue tape, I have generally found some layers that stuck together but didn't quite fuse.
The rescue tape seems to be less pliable after fused...kind of like a soft plastic rather than the consistency of silicone rubber.
The rescue tape is definitely cheaper.
The mil spec tape bonds quite well to SCAT tubing; the rescue tape, not as well.
I have used both on my -10. I have been using the rescue tape for strain relief on wiring connectors. I have used the mil spec on the ends of my SCAT tubing to help prevent the wire from tearing the tube...it makes a really nice finished end.
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
