Go Back   VAF Forums > Model Specific > RV-14
Old 08-19-2019, 03:08 PM
mturnerb mturnerb is offline
Default So who else has seen broken sniffle line bracket
I did some FWF inspection today at 46 hours or so, cowling off. Found that the sniffle line bracket was broken, so I replaced it by fabricating a similar piece from stainless steel. I've seen a builders blog where the theory was the exhaust heat weakens the aluminum bracket.
Photos here:
https://turnerb14a.blogspot.com/2019...nspection.html
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 08-19-2019, 03:18 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Mine, twice so far. Next time I'm drilling a hole and putting it on the other side of the clamp with just the head of the screw above the clamp.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 08-19-2019, 03:23 PM
Bavafa Bavafa is offline
Photos here:
I found mine broken at around 81 hours. I was thinking either stainless steel, or simply use stainless steel cable which gives it flexibility if the cause is vibration and not heat.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 08-19-2019, 04:58 PM
JDA_BTR JDA_BTR is offline
Same. I just took it off. Will let the hose flex and see how it goes. Stainless is a good idea.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 08-19-2019, 05:32 PM
I think Van's probably needs to redesign the part or find a better way to support the hose. I'll see how the stainless works - it was pretty easy to fabricate - I happened to have some .018 stainless laying around.
Turner Billingsley
Old 08-19-2019, 06:43 PM
Scott Hersha Scott Hersha is offline
Yep. Made mine out of steel from the beginning. No failures..
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 08-19-2019, 07:09 PM
Ron B. Ron B. is offline
Had to replace mine as well.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 08-19-2019, 07:21 PM
I don?t think I have a little piece of stainless for this. Did y?all adapt something else?
Old 08-19-2019, 08:45 PM
I had some I bought to make a shim. .018
Turner Billingsley
Old 08-19-2019, 09:01 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Sniffle valve
You might consider just removing the sniffle valve. I?ve never actually used mine.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
