Old 08-18-2019, 04:01 PM
Patr Patr is offline
Default Help Identifying Correct Governor Adapter for 0320
Hello
Wondering if anyone can help me identify the correct governor adapter and other parts for my 0320 and best place to purchase these parts.
0320 experimental built by Lycon 20 years ago. Not sure of the model number, using the Lycoming Parts Catalog PC-203-2 0320 B and D Series
I?m trying to determine the difference between the 75153 adapter assembly for Woodward governor installations and the 75545 for ?AN? governor installations. Think I need to use the 75545 but not 100% sure.
Planning to use:
PCU 5000X governor
75167 SS oil line
MS20822-6 fitting for the font of the crank case
74070 45 deg. fitting for the adapter
Appreciate any help you can provide.
Pat
Pat Ryan
RV6A
Ramona CA
Old 08-18-2019, 04:13 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Aircraft Specialty Services (www.aircraftspecialties.aero) and Aircraft Spruce are good sources for these supplies. As for which governor adapter, I'd search for the Lycoming Parts Catalog for specific model engine. I've always found that a reliable way to verify the part numbers.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
