Old 08-16-2019, 04:42 PM
bobnoffs bobnoffs is offline
Default removing pop rivets
i guess i have been doing ok removing rivets by pounding out the mandrel with a small punch. a lot of the success depends on how rigid the material is around the rivet. is there any tool made that would deliver maybe a spring loaded hit on the mandrel? or anything better than the hammer and punch?
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 08-16-2019, 05:20 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Spring loaded automatic center punch.
Harbor Fright has them.
https://www.harborfreight.com/automa...d+center+punch
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-16-2019, 05:41 PM
DHeal DHeal is offline
As Mike said, get a spring-loaded automatic center punch. You should grind down the diameter of the center punch's pointy-part to fit the rivet mandrel hole. In some cases you might want to support the skin material on the backside of the rivet to prevent denting of the surrounding skin -- a wood or metal block with a 3/16" hole for the rivet body works well.
ps -- I like to try to collect the little steel mandrel nibs that pop out of the backside of the rivet to keep them from rattling around -- you will likely not get them all. A magnet on a stick is useful in collecting the little buggers.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 08-17-2019, 05:12 AM
great idea. motorcycle ride to h.f. today.
Bob Noffs
n. wi.
Old 08-17-2019, 08:44 AM
rongawer rongawer is offline
This little fun toy removes pulled rivets in about two seconds with no "oops" required. https://www.aircraft-tool.com/shop/detail.aspx?id=1341S
Not HF cheap, but it's not cheap either... nice product.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
