05-01-2007, 08:28 AM
Rib stickers
Those little white rib stickers are driving me crazy. They won't come off. I have had to use a scraper which ends up scratching the parts and then have to scrub the rather persistent glue off with lacquer thinner.
Anybody have a better way?
Van's needs to start using easy peel stickers. It would save us a lot of hassle.
Ravi Thakkar
Charlotte, NC
RV-9A(flying)G3X, GTN650, Garmin autopilot
RV-8(flying) Steam guages. Love 'em
05-01-2007, 08:32 AM
Quick and easy method.....get a bucket of warm water with a small amount of dish soap. Let it soak for about 15 seconds, then peel right off.
05-01-2007, 08:52 AM
Originally Posted by rockit
Anybody have a better way?.......
I actually discovered this stuff by way of my wife. In her home office, she uses it to remove uncancelled postage stamps from envelopes. I use it to remove old adhesive labels from my parts bin drawers and all manner of stickers that come with todays products....including Van's sticky stickers. Works like a charm.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
05-01-2007, 09:26 AM
Try Goo Gone. Can find at hardware and department stores. I scraped the majority of the tags off with a plastic kitchen dish scraper, then used Goo Gone to rid the part of the glue. Works great!
05-01-2007, 11:40 AM
Goof Off
I peel them off as best I can, then use Goof Off to dissolve the adhesive. Goof Off is little more than lighter fluid, as far as I can tell. Great stuff to have around. You can get it a Home Depot, in the paint department.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
05-01-2007, 11:54 AM
Since I have lots of Isopropyl alcohol lying around, I just use an old sock to soak up some and dab it on the label - the paper soaks it right through to the adhesive on the back side and it peels off easily. I used to use it for scroll saw woodworking to get the spray-glued on patterns off the wood after cutting.
Kai Schumann
RV-8 Dreamer
Daily Lurker
VAF # 676
05-01-2007, 12:23 PM
Chief Obfuscation Officer
Goo Gone
Safe (citrus based), cheap, and VERY effective. You can get it at most local hardware or grocery stores. Oh yea, and it is safe for getting the residue off of the powder coated parts without dissolving the powder coat.
05-01-2007, 12:33 PM
If you're going to prime, you have to clean them with some sort of solvent anyway. Just save yourself the time and do it then. For me it was lacquer thinner that both prepped the ribs for priming and removed the sticker residue all at once.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
05-01-2007, 05:57 PM
I use acetone--it's what I use to degrease the parts anyway. Put a little on a paper towel, hold it tight against the sticker for a few seconds, scrape it off with a popsicle stick & clean up the residue with the acetone on the paper towel. If I soak it longer than a few seconds, maybe 10 or 15 seconds it comes off easily and cleanly and I don't have to use the popsicle stick.
If I remember correctly, the active ingredient in Goo-gone is xylene, with a bunch of stuff to mask the smell. Xylene is about as toxic as acetone, so use it with gloves. De-solv-it doesn't say what the solvent is, it just says it's biodegradable.
05-02-2007, 06:44 AM
MEK
Bob collins
St. Paul (trying to make the message longer so the system will take it)
