  #11
Old 08-17-2019, 08:28 PM
Pilot8 Pilot8 is online now
Did you drill the drain hole in the bottom of the snorkel?
Old 09-05-2019, 03:49 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Originally Posted by Monkey View Post
Just a tad too lean. Run the boost pump 1-2 more seconds.
+1 What monkey said...this is backfiring during start from too lean a mixture. You can enrich the mixture buy priming more with boost prior to start, or start with throttle at idle and advance during starting.
Old 12-18-2019, 07:28 AM
witek witek is offline
Default Backfire
English is not a problem here but what do you mean - "did you drill the drain hole in the bottom of the snorkel?"
Where the drain should be located?
Witold
