Old 08-12-2019, 03:40 PM
Girraf Girraf is offline
Default Reversing stiffener orientation on tanks
I've looked at a lot of build logs and everyone seems to have installed the stiffeners according the drawings (with the vertical member toward the aft side). I match drilled mine to the skins in the reverse orientation after seeing this note and thinking it would be easier to backrivet them this way. Anyone else actually do this?
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 08-12-2019, 04:04 PM
ryankhallcpa@yahoo.com ryankhallcpa@yahoo.com is offline
Yes, I reversed mine as you describe. Everything came together just fine and I repeated the orientation on the second tank.
Taylor, AZ (KTYL); Builder #74649
RV7 N789YZ - Emp done; SB Wings done; SB Fuse done; FWF done; Wind screen in progress
XIO-360-M1B 9.0:1 pistons; built by JB Aircraft Engines
67 Cherokee 180C - Flying
USAFA - Son (class of 2022)
Donated Q4, 2021
My flight bag is made by Dewalt!
Old 08-12-2019, 04:24 PM
Thinking about this a little bit more: This orientation gave me good visibility to the shop head while back riveting the tank stiffeners. However, visibility to the forward side of the stiffener was limited (due to the flange) for purposes of assuring a good fillet of sealant. But, not a big deal; I just used a mirror to check each one. Again, I repeated the orientation on the second tank and both tanks passed the soapy water leak test, so I was happy with it.
Donated Q4, 2021
