Old 08-11-2019, 06:02 PM
Drifteral Drifteral is offline
Default Mis-matched starter to ring gear.
Got the overhauled parts for my O-320-A1A back together. I was going to install the starter that came with the engine and something is not right.
The starter is Prestolite MZ-4206. Ring gear is a 72566 149 tooth with a 76628A support.
The ring gear I ordered last summer and it was supposed to be a 74414 but after further inspection i found the actual part number on the support and it was wrong. Unfortunately I cant send it back now.
Now which way do i go?
Al
Old 08-11-2019, 06:07 PM
This thread tells you how to remove and replace the ring gear:
http://www.vansairforce.com/communit...g+gear+removal
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-11-2019, 06:32 PM
lr172 lr172 is offline
It was my understanding that the ring gears are not universal and must me matched to the correct ring gear support. Something about the widths being different.
Larry
