Originally Posted by thompsonbr87
A couple of other thoughts I had were increasing the panel cut-out size and making a mounting plate just large enough to accommodate the full body of the jack. Or slightly counterboring to the size of the washer - maybe driving a step drill bit by hand? Also considered putting in a 1/4" jack and using a 1/4" to 1/8" cable to connect music.
Thanks. I did ultimately find a jack with enough depth and a thin enough shoulder washer. I was mentioning for others sake, as it was not easy to find and the common ones are just begging for someone to leave out one of the washers in our application.
Larry
