Old 08-07-2019, 02:53 AM
EdH's Avatar
EdH EdH is offline
Default Interesting hot air diffraction flow photo detail?
Looking through some shots I took of my buddy Steve flying our -8, and spotted an interesting visual display of the hot-air exit flow from the bottom of the cowl (and the exhausts).
Just something you don't usually see, and is down to light refracted differently through the varying temperature bits of air. I think the background helps make it obvious in this shot.
A crop from the image.
The full shot.
Ed.
RV-3B G-CCTG - Purchased May 2020
RV-8 G-MIRV - First flight 1 July 2019
RV-6 G-BZRV - Flown the nest.
Last edited by EdH : 08-08-2019 at 04:22 AM. Reason: Changed Diffracted to refracted - thanks Erich
Old 08-07-2019, 11:47 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Nice looking 8!
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 08-07-2019, 04:39 PM
Marc Bourget Marc Bourget is offline
control said: "I would have expected more turbulence"
I don't think the exhaust has the density/mass to oppose the slipstream and generate significant turbulence.]
FWIW
Old 08-07-2019, 06:41 PM
AlexPeterson's Avatar
Very cool picture!
I cannot tell what the exhaust is doing - the background changes at precisely the wrong spot.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 08-07-2019, 06:59 PM
scard's Avatar
scard scard is offline
Very neat. Very similar in nature to being able to "see" things you never imagined in a sound "image".
Scott Card
CMW E-Lift
VAF Advertiser
Old 08-07-2019, 08:32 PM
erich weaver's Avatar
Cool, good eye. Minor correction: the light is being refracted rather than diffracted. Diffraction is something else.
Erich
Old 08-07-2019, 08:44 PM
Steve Melton's Avatar
there goes 75% percent of the available thermal energy
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 08-08-2019, 04:21 AM
EdH's Avatar
EdH EdH is offline
Erich
Thanks Erich - will tweak the first post.
Ed.
