  #11
Old 04-30-2007, 05:59 PM
Gary Bricker Gary Bricker is offline
Smile Gary Bricker
Where can I get the regulator and hose for nitro. I can get the bottle at a local welding supply but they were not sure about the regulator and hose.
Old 04-30-2007, 08:46 PM
Larry D Larry D is offline
Default COSTCO article isn't accurate!
Any knowledgable chemist can tell you that there are statements in the Costco article that are factually incorrect. It is true that rubber is somewhat permeable and gases can leak out through the rubber sidewalls of a tire. However in practice I expect that the most important leak source is either the valve or the failure to seat the bead tightly on an auto tire. Aircraft tires use inner tubes so a leak at the bead can't happen. If you lose air you might want to use the special air retention inner tubes available for aircraft which are especially low in permeablility. The article indicated that oxygen would leak out three to four times as fast as nitrogen. This is just not chemically correct. The molecules are nearly the same size and weight. That means they should diffuse through the slightly porous tire wall at rates that are not very different ( 1.07: 1) with nitrogen the slightly faster. See you basic chemistry text - Graham's Law of Diffusion.
In an auto tire the presence of moisture could promote corrosion of the steel rim. There is no tube in an auto tire normally and the water that could be in air along with the oxygen could cause rust to form on the rim. This is not a problem in aircraft.
The expansion and contraction of nitrogen and oxygen (and all gases for that matter) are the same with temperature.
If you want to spend the money and use nitrogen that is your choice but it is unnecessary.
Larry Dickinson, chemist
RV-9A 160 hours
N95LD with air in the tires
Old 04-30-2007, 09:10 PM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
RV-9A 160 hours
I agree with Larry completely and will continue to use "air" but don't want to discourage anyone that wants to feel good about their tires because they used nitrogen.
How readily available is nitrogen away from your regularly used place of inflation might be one question to consider?
Personally, I find that there are enough maintenance items to worry about on an aircraft and do not want to introduce one more.
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
Old 04-30-2007, 09:25 PM
airguy's Avatar
airguy airguy is offline
The reason some shops use nitrogen is because it is DRY - moisture promotes bacterial growth on the rubber, which degrades the tube and tire.
Run your air through a dessicant filter, you'll get the same effect.
Fellow Chemist....
Old 05-01-2007, 10:48 AM
osxuser's Avatar
osxuser osxuser is offline
Hmm, I use nitrogen in struts, but never in tires, seems like waste. Airstop tubes when you wear out the tires will take care of the problem. If you ever had a problem.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 05-01-2007, 11:01 AM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Default Costco Article
here is an article explaining Costco's rationale.
This sort of falls into the category of the New Science by Al Gore.
The media falls for it hook line and sinker and, before you know it, it becomes "fact".
It reminds me of many appropriate sayings I learned as a kid and I would provide attribution to these but have long forgotten the proper source:
"A fool and his money are soon parted"
"There's a fool born every minute"
"No one ever went broke underestimating the intelligence of the public"
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 05-03-2007, 12:23 PM
jarhead jarhead is offline
Not 100% true. Most GA tires are tube-type, but nearly all business/airliner-type aircraft use tubeless tires. Nearly all helicopters with wheeled gear use tubeless tires as well.
Corrosion on aircraft wheels is a common problem, whether they are tube-type or tubeless, filled with air or nitrogen. Just a matter of where the corrosion occurs...
I always thought (and had been told numerous times) that nitrogen was more "consistent" re: expansion than air under high temp/pressure. Guess I should've paid more attention in high school chemistry...
Nitrogen is used in aircraft tires because it doesn't support combustion. Very important in the event of a brake fire after a heavyweight landing or RTO, or a wheelwell fire with the gear retracted.
I personally don't see a reason to use nitrogen in RV tires:
- there's plenty of flammable fiberglass surrounding brakes that 99% of builders fill with flammable MIL-H-5606 fluid.
- unless you can get the nitrogen for free, air is cheaper for 99% of owners.
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
Old 05-03-2007, 06:19 PM
szicree szicree is offline
Man, this nitrogen thing sounds like magic beans to me. Once and for all, air is mostly nitrogen. Now if dryness is the concern, can't I just use a drier on my compressor line (maybe wait for low humidity days to air up) and get most of it out?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 05-03-2007, 06:30 PM
Hwood Hwood is offline
Default Easy
Easy math...Let's see, Small charge for nitrogen vs Air for free.
Sounds like a "no brainer" to me....this ain't rocket science, right Paul?
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
Old 05-03-2007, 08:22 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Well, I know that we use Nitrogen in the Shuttle's tires....but the Val gets pure, unadulterated (humid) Houston "air" (if you can call it that....)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
