Old 08-04-2019, 08:28 AM
ltn6a ltn6a is offline
Default First engine start attempt
Hi all
Looking for some wisdom from the forum.
Attempted first run of my IO-320-B1A in my RV6a
Following the lycoming start sequence ,fuel pump on ,full throttle and full mixture , I got 35psi fuel presss but no indicated fuel flow .
Pump off , mixture idle cut off and throttle 1/4 .
After various attempts managed the odd cylinder to fire but could not get it to run , checked plugs a bit damp but ok . Replaced upper with new plugs .
Still occasional cylinder would fire .
Started investigating the fuel system and with fuel pump on we have good flow right up to the Bendix injector body but regardless of mixture or throttle position no fuel flow / out put.
Pulled the inlet screen filter and it clean so looks as if the injector body is not working .
The engine was stripped and rebuilt about 10 years ago but nothing was done to the injector .
Any advice or suggestions before I pull the injector for a service/ bench test
Mark
Old 08-04-2019, 09:00 AM
Allan Stern Allan Stern is offline
Default Start
Check timing? If rebuit 10 years ago, timing could be off.
Old 08-04-2019, 09:04 AM
Hi Allen
Will do 5hat but current concern is that we can see no real fuel flow from the injector body out let that feeds the spider.
Mark
Old 08-04-2019, 09:26 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Verify mixture arm going right direction.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-04-2019, 09:31 AM
Thanks Mike will add that to the todo list
Mark
Old 08-04-2019, 09:56 AM
Toobuilder's Avatar
After the servo repair, but before you grind on the starter any more (and wipe away ALL lube on the cam), make sure you perform an injector flow test. This will exercise the fuel system and verify the integrity of all components. Assuming you have good spark, it should fire and run.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-04-2019, 10:18 AM
Thanks Michael
I will do a search as I don?t recall seeing this in the lycoming operators manual
Mark
Old 08-04-2019, 11:16 AM
9GT's Avatar
9GT 9GT is offline
Purge the air out of the lines by disconnecting the fuel supply line and the fuel divider and running the electric boost pump until you have a solid air free stream of fuel. Make sure you do this safely and run the fuel into a bucket.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 08-04-2019, 11:25 AM
Hi David
We get good fuel flow to the servo body but no real flow from it .
Exercised the throttle and mixture with fuel pump running no change.
Pulled the servo. Body filter but that was clear
Mark
Old 08-04-2019, 12:17 PM
ethand ethand is offline
Default No Airflow No Fuel Flow
I am not sure this will help but will share my experience with my Airflow Performance throttle body/injection.
Summary is you will not get much fuel flow if there is no metered airflow in the system.
When I did my fuel flow check I disconnected the fuel line at the spider valve and flipped the fuel pump switch to find it trickling out of the hose, not a solid stream. Switched tanks, no joy. I then disconnected the line going into the throttle body, and like you, had full flow. Researched a bit (and confirmed with a call to Don) that there will be very little fuel flow because the system is not seeing the airflow across the venturi to know it should be pumping more gas. One way to test this is flow compressed air in the venturi and see if the FF increases with the electric fuel pump on.
Point is I guess it may or may not be the TB.
Hope that helps.
E
RV-10 N77319
2192 Days of Building
Completed May 2019
Phase 1 completed Nov 2019
210 hours and counting.....
