Hmmm.
First, you do need to have a sealed passage, so air doesn't come in through the opening and flood into the lower cowl area. That probably goes without saying.
The idea of extending a tube out in front of the cowl surface a short distance is that it captures flow fairly straight on, before the flow turns to follow the sloped surface of the cowl. Depending on how far in front of the cowl surface the inlet extends, you get a fairly high fraction of the available ram pressure rise.
If you have just a hole, with a radius lip feeding into a tube, you will still get some 'ram' pressure, but because of the slope of the cowl and the flow around it, you probably won't develop full stagnation pressure.
At sea level at 170 kts, the pressure rise to stagnation from free-stream static is about 1.4 in" hg. There is probably also a slight additional rise from the propeller velocity addition, but that is pretty small at cruise conditions. If I were to make a WAG, I would say that a flush hole on the forward face of the cowl where an intake tube would go that is the same diameter as the fuel servo might get something like 1/4 --1/3 of the stagnation rise. So something like .3 --.4 in. hg. So you would be giving up about 1" hg. MAP. Again, this is really just a guess. If you make the hole bigger and feed into the servo with a smooth transition, you will get more of the available ram pressure.
There might be an in-between solution that would appeal to you. If you can build up an area that is locally perpendicular to the flow rather than sloping, and blend that into the general lines of the cowl, you might get a shape you are satisfied with, and get something closer to 80% of stagnation, and not have a full tubular "pitot tube" sticking out.
You could also think about a more tailored inlet shape, like the "smile" inlet on a F-1 Rocket or the P-51. That's what I did. Mine does not extend forward of the cowl surface as far as the Rocket, but it does extend forward a little with a lip. The P-51 doesn't have any lip at all along the top edge. With a supercharger, I think you get the manifold pressure you want, whether you start out a little higher or not from the inlet design.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
