Old 08-02-2019, 12:57 PM
s24789 s24789 is offline
Default Nose Gear Issue (Long Gospel)
Late last year we developed what we thought was a nose gear shimmy on our RV-7A. The aircraft has 1000 flight hours. It started as a light amplitude shaking noticed on roll out when we were going slow prior to exiting the runway. We had a friend watch us land and roll out. He noted that the motion of the nose wheel was vertical (nose strut bending along the longitudinal axis) and not horizontal (shimmy). We then jacked the aircraft and inspected and found the nose landing gear attach bolt near the firewall had lost torque. We replaced the bolt and retorqued. The joint seemed tight.
We were planning a panel upgrade so we went down then for the next five months. While we were down we removed and repacked the nose wheel bearings and conducted the pull test. All was well.
Fast forward post panel up ? Things got worse. If we did not consciously hold the nose off on landing roll out, we would get a violent motion that shook the entire plane on landing deceleration at slow speed. We then conducted taxi tests and determined that at 24 knots ground speed while decelerating we would get the vertical motion/shake. This vibration never happens on take-off most likely due to off-loading of the nose gear during acceleration.
Last night we tied the tail down (nose off the ground) and banged the nose strut both vertically and horizontally. Horizontally it is extremely well damped. Vertically it looks like a tuning fork that eventually damps but rings noticeably for a period of time. Obviously, we have looked for a cracked engine mount and cracked gear leg with no findings. Additionally, we have the AntiSplat nose job installed however, we operate from hard surface runways and only have about 10 grass field landings in 1000 hours.
Things we had done in an attempt to remedy the situation;
Replaced nose tire with new one ? No change
Reduced nose tire pressure to 30 psi ? No change
Rechecked the pull test on the fork ? No change
Replaced main tires, rebuilt right brake caliper (it appeared to be sticking a little, repacked main wheel bearings, replaced brake pads ? Have not flown this configuration yet.
Has anyone experienced this and more importantly what is the corrective action? The new nose gear damper appears promising but is a big job.
Kevin Phelps
Paid thru Dec 2022
RV-7A flying N782WP
Stuart, Fl
Old 08-02-2019, 01:15 PM
Sounds like the nose wheel bearing is binding under load. I machined my wheel for ball bearings, it is much better now, with very little rolling resistance. If you have access to a lathe, you can do it yourself, or send it to antisplat.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 08-02-2019, 01:24 PM
F1R F1R is offline
Default A Whole lot of shakin going on!
There are many past threads with sage advice on nose gear health and maint. tips. ( See the excellent link in post#5 below )
Assuming the castor bushing is in good condition and break out force is correct, balance the MAIN wheels AND the NOSE wheel.
Please report back after you have tried balancing the 3 wheels/tires.
Your own words "If we did not consciously hold the nose off on landing roll out"
As with any trike gear light single I can't imagine not wanting to do this on every landing and take off even if everything else is perfect and with no shimmy.
The nose wheel is only a parking dolly.
https://youtu.be/xraIf_cYRQE?t=47
Since the OP mentioned the Gospel, Jerry Lee Lewis was thrown out of seminary for hamming up the hymns. As a result he was able to reach millions of people through his music.
This one fits the thread. Enjoy.
Old 08-02-2019, 01:43 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The antisplat nose reinforcement will add mass to the leg------no idea how much this effects the vibration, but I suspect there is some.
And, I second the prior comment about keeping the nose wheel off the ground during take off and landing.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-02-2019, 01:55 PM
AlexPeterson's Avatar
Please read post #1 of this thread before you fly it again. Pay particular attention to the wheel bearing design discussed in "3. Nose Wheel" of the post. It is possible for the nose wheel to lock up, making for a very bad day.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 08-02-2019, 02:30 PM
Discus2b Discus2b is offline
Bull....Vans would not have his engineers do such a poor job as to require all his
?A? s rolling out or taxing around with the yoke in the gut and the tie down ring dragging on the ground.
Pilot A ?Hey , there?s a Van!?
Pilot B ?How can you tell??
Pilot A ?Look at the elevator, it?s all the way up?
Pilot B ?Why??
Pilot A ?It?s to prevent the nose gear from ripping off?
Pilot B ? Wow, that ain?t good!?
The thread ops said his problem just started, so his original install worked.
It is very apparent that the design while adequate for the test pilot, not so for the masses. Risk a prop strike or perform the upgrade for those with marginal skill set. Those who feel they have the touch, wisdom, ...steady as she goes.
Old 08-02-2019, 03:14 PM
Mike S's Avatar
Senior Curmudgeon
Bull???
Mike Seager, over (IIRC, 10000 hours instruction) of RV time and the go to guy for transition training is who told me to always get the nose up asap on takeoff, hold it off as long as I can on landing, and taxi with the stick in my gut.
Your quals as an RV instructor????
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 08-02-2019, 04:43 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Nose wheel needs mod
Kevin,
Previous commenters pointed out the apparent drag on wheel rotation being caused by your nose wheel bearings. I ASSUME you have the stock unsealed ?pack?em yourself? bearings.
Here?s what?s happening. Stock bearings don?t allow the wheel to spin freely enough, creating drag on the wheel which pulls it back, thus bending the nose strut back. Then the strut?s spring forward overpowers the bearing drag. Repeat. Now you have this oscillatory vibration that feels like a shimmy. It usually happens at speeds you described. Looks like:
https://youtu.be/Cxoa_t0NJ6s
I had it too, and ordered Antisplat?s nose wheel mod:
https://antisplataero.com/products/n...el-bearing-mod
The sealed bearings are far superior. I have not encountered this oscillation since buying the mod.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 08-02-2019, 04:54 PM
rvbuilder2002's Avatar
Not saying that it couldn't be a bearing problem but assuming that automatically could be missing the real cause.
As already mentioned, an out of balance wheel/tire can excite a motion, but an out of round tire will as well.
That is the very first thing I would check.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-02-2019, 05:38 PM
NewbRVator NewbRVator is offline
Bull???
In other words fly it like a tailwheel
21 dues paid member since 2018
RV6A
