Primer options
I started out in mid-90's using a Wattyl eurocryl self-buffering etch primer that was zinc chromate based, but it is no longer available due to health risks (carcinogenic). Recently investigated everything I could locate in Australia; Akzonobel, PPG etc. and anything aerospace related is around $700 per gallon. The Stewart Systems water based primer is around $300-$400 per gallon, I understand it is a bit harder to apply, but works well.
For painting the exterior, I've settled on Nason 2-pack epoxy primer. This will be top-coated and it provides a very tough barrier, but it's a hassle to put on because it is toxic (isocyanates - needs a forced air breathing system) and pot life is limited. That makes it impractical for preparing small parts.
My understanding of single pack etch primers, e.g. Wattyl self-etch, is that they are designed to be over-coated. They are porous, so they don't provide any real protection from corrosion on their own.
I've had good test results with Dulux all surface metal primer. If the aluminium is scuffed with red scotch brite and degreased, it sticks very well. After a week of curing it is very abrasion resistant. Cost is less than $100 for 4 litres. I have decided to use this to prime the inside of the fuselage where there are lapped joints in Alclad 2024, and for all 6061 and anything that is steel.
Alodine would also be an option, but it too is toxic and very time consuming.
I am aiming for an airframe that will last about 20 years. I would rather fly a bit sooner, than over-kill with corrosion proofing.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
