Old 07-30-2019, 12:37 PM
cofford cofford is offline
Default Pitch servo installation
I'm installing my pitch servo and noticed that the AN470 rivets shown here interfere with the servo brackets:
I've done a lot of searching and haven't seen this mentioned elsewhere, so am I missing something? A simple solution could be to drill out the AN470s, countersink, and install AN426s. What have others done here?
Casey
Old 07-30-2019, 01:20 PM
N546RV's Avatar
N546RV N546RV is offline
I went back in my build log to where I installed these brackets, and if I did anything special, I didn't mention it there: https://rv.squawk1200.net/2016/04/01...ervo-brackets/
I'll try to remember to take a look when I get home tonight and see if anything interesting jumps out at me. This part of the fuselage is wide open for inspection right now, so it's an easy thing to check.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 07-30-2019, 01:29 PM
Wunderon's Avatar
Wunderon Wunderon is offline
Not sure which servo you have but for the Dynon there was room on mine to put in 5 or 6 -4 rivets without getting into the bellcrank rib.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 07-30-2019, 01:32 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Garmin mount? The brackets should be aft of those rivets if I recall correctly.
>>>> oops wrong. Hey, I was at work! The bracket is over the brace rivets. I installed the top 470's (longer) through the brackets, rib, and brace.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 07-30-2019, 02:06 PM
I'm using a GRT mount. It looks like they are a bit longer than the Dynon mounts...Maybe trimming the mounts a bit is a better solution. Anyone have a picture showing the mount and the rivets in question?
Edit: the Dynon mounts look to be the same length in this photo:
To me, it looks like the pitch servo bracket would be sitting on the AN470 Bellcrank Rib rivets, which would require me to do something about it.
Old 07-30-2019, 07:20 PM
Wunderon's Avatar
ah I see, yes replacing the 470s with 426 will work. I don’t think I used any of the small 470s in the build.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 07-30-2019, 07:51 PM
N546RV's Avatar
As promised, I checked out my build. Since I installed Dynon brackets, I figured I must have done like Wunderon said and just had them not overlap, but...nope, there's definite overlap:
Looking at it edge-on, everything is clearly sitting flush here, as it should be:
I can only assume that I countersunk for flush rivets in those four spots.
Philip
Old 07-30-2019, 08:09 PM
Allan Stern Allan Stern is offline
Default Servo brackets
Do you think that the AN 470 rivets go through the servo brackets? The picture does not show an auto pilot servo bracket installed. It only is showing the elevator bell crank brackets. An auto pilot is extra and not part of the plans.
Allan
RV 6A sold
RV 8A sold
RV 12 flying
RV 14A being built
2019 paid
Old 07-30-2019, 08:11 PM
resrob66 resrob66 is offline
Default Pitch servo bracket....Garmin style
I did mine like this.
Robert
RV-8 Showplanes Fastback
Finally complete!
Old 07-31-2019, 02:00 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default pitch servo installation
Here's how I did it.
http://www.rv8.ch/autopilot-pitch-servo-installation/
I made the bracket a bit longer so that it would be easier to remove the servo if needed. The Dynon instructions were very useful, even though it's a GRT servo. I would also consider buying the Dynon install kit, it's really complete.
Mickey Coggins
http://rv8.ch
"Hello, world!"
