RV74ME...I appreciate your concern. It is one of the issues I have with our suppliers and their catalogues which list coax cables (such as RG 400) and coax connectors for that cable.
Here is what needs to work together:
The coax cable needs to be prepared such that the male pin will properly seat in the connector with the proper and required snap. At least today's connectors provide that tactile feedback. BNC connectors of yesterday had no such feature.
The coax cable dialectic layer which surrounds the center conductor should slide into the connector guide tube with no slop. It should just fit. This is one of the areas where different coax cable types (RG 58, RG 59, RG 400) will have different diameters and thus drive a different connector body p/n. Speaking of the guide tube...different manufacturers use different length guide tubes, and this drives the trimmed brade length and dialectic cut back dimension and outer jacket trim back.
Then there is the branded outer layer of the coax cable. Is it one layer as in RG 58 or two layers as in RG 400? With two layers, this outer "shield" is thicker, and this drives the crimp barrel dimensions. The two layers of brade are better at maintaining our 50 ohm impedance when the coax cable needs to make a tight bend.
I know this doesn't really answer your question, and I don't really have one for you. It is just something I (we) have to deal with when our suppliers sell us our components.
Noel
RV-6A N6NF
tip-up
flying
