IO360-A3B6D Crankshaft Replacement
Hello Guys,
Wondering if someone might be able to help me on this forum. Can I install a non-counter weight crankshaft from a 180 HP O-360-A1AD in my experimental 200 HP IO-360-A3B6D? I understand that the connecting rods will need to be changed. Will my crankshaft gear fit. Both crankshafts are for dual mags and have the ? inch bolt/3/8 inch dowel for the gear but the gear part numbers are different. What is the difference in the gears?
Daryl
