Originally Posted by SFB711
RV-6A with a XP-360/Precision carb with a carb temp sensor in it. The probe reads ambient temperature on the Dynon EMS just fine. When carb heat is applied I only get a few degree rise in the temp. I have the carb heat kit from vans installed on the exhaust just above the airbox. Anyone getting different/better result? Thanks, Steve B.
Yep crummy results are common. What "painless" said. Cheers
If you do a search on archives you will see much discussion. The good news is the Lyc is carb ice "resistant" (not immune) and the RV cowl and exhaust are tight which tends to keep it carb warmer. However long long descents at low low power with the temp/humidity just right and you can lose power. It's rare, but there is one or two documented suspected RV carb ice cases in the NTSB files. Of course its always hard to prove, when the evidence melts at the scene of the accident.
Run up temp rise is a good indicator but the real indicator would be in flight with a low power setting.
