Old 07-22-2019, 01:45 PM
Scott Kelley Scott Kelley is offline
Default Cleanup of 83282 hydraulic fluid?
This stuff seems impervious to petroleum based solvents - what to use to clean from firewall and floors?
Old 07-22-2019, 01:50 PM
N804RV's Avatar
N804RV N804RV is online now
Non-chlorinated brake cleaner. Used to use Trichlorethelyne as a solvent for hydraulic analysis testing. But, that stuff is muy mal!
Non-chlorinated brake cleaner is about the closest off the shelf product that is the least harmful to humans, pets and aircraft. Just be careful with it on your paint job, it can dull the paint.
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 07-22-2019, 10:09 PM
Louavul's Avatar
Louavul Louavul is offline
Pryor to retirement we used Zep Solve for everything oily, greasy or whatever, the stuff is awesome if you can find it and if you can get it in affordable quantities.
http://www.superkleendirect.com/zep/...solv-1-gallon/
Steven Hild
Rio Communities, NM USA
RV-7, N590SC Flying
Contributing annually since January 2002
Old 07-23-2019, 12:00 AM
xblueh2o xblueh2o is offline
I have had very good luck with CRC Electrical cleaner. It will even clean old dried out fluid. Available at every auto parts store etc.
Get the one with the picture of the molex like connecter on it, not the one with the alternator.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 07-23-2019, 12:09 PM
Mach2 Mach2 is offline
Smile
I had a hydraulic leak from a pedal last year, it ran back down the fuselage and could not get the residue off and dust and stuff stuck to it. Last week I happened to try isopropyl alcohol (rubbing alcohol). It cleaned off easily and did not damage the paint. Result.
Old 07-23-2019, 02:10 PM
DaleB's Avatar
DaleB DaleB is offline
Really? I could swear I've cleaned up some thick, gooey drip/leak residue with mineral spirits. The clear kind, not that fake white "eco friendly" stuff commonly found in some home improvement stores.
Dale
Omaha, NE
Previous RV-7 project (sold)
