Picture the rear spar moving on an ARC, not straight in and out, because that's kinda how it is. The front spar does allow the wing to flex fore/aft. That's how we adjust sweep, after all.
Anyway, when the wing is 100% in final position, the rear spar will be in perfect fore/aft position, but until then if the sweep is off even slightly, then the rear spar won't be aligned with the "fork" on the fuselage. You gotta start working that rear spar in long before the front spar goes all the way in.
You may have to "encourage" (a.k.a. pry) the fork apart slightly to get the rear spar in as you feed the wing into the fuselage. The more helpers the better. I've done it with 2, but 3 is mo betta.
BTW, I've seen this before when mating wings on -7[A]s with both slow & QB wings.
Dan Checkoway RV-7
