Originally Posted by erich weaver
I have a shallow, silver-dollar size dent on the rear fuselage top skin, where it extends into the baggage area of my -7A. I was standing on a stool leaning into the cockpit area when....well, you get the idea.
thanks
If the shallow dent is a curved section of the skin, it sounds like it. The area should not have been streched. It just got reversed!!!
Try this..... Mask the back area of the dent with blue tape or electric tape and then take a spoon and rub the dent out. Press hard with your thumb in the spoon. Start around the edges and work to the center. If you can watch it from the top, you will get better control.
When you have given it your best shot, then if needed fill the rest. At least the filler will be thinner and less chance of cracking.
Tell us what happens......good luck!
Warren
