Old 07-07-2019, 08:17 AM
74-07 74-07 is offline
Default GDL-82 install tool question
Downloaded install tool multiple times. Each time, when I try to begin install config and ground checkout, all I see is a screen that says ?Modify Setup? and offers the option to repair or close. Tried ?repair? and it just eventually says ?repaired? and closes the program. What am I not understanding or is there a problem with the program?
Old 07-07-2019, 10:42 AM
The problem is resolved. One more step towards 2020 compliance!
Old 12-26-2019, 12:11 AM
Jake14 Jake14 is offline
I'm getting the same gdl82 install problem, it keeps wanting to repair the program ...what was the solution?
RV-14A flying 410 hrs
Old 12-26-2019, 05:17 AM
Walt's Avatar
Walt Walt is offline
Try opening the GTX program from the Microsoft pull down menu and not from the desktop shortcut.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-26-2019, 05:24 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Jake,
We helped one customer who was trying to "run" the GDL 8X Install Tool from the "Apps and Features" section of Windows 10, and was only ever getting options to Repair or Uninstall the PC tool. This is normal when selecting an application this way within Windows.
Make sure you left click on the Windows start menu (lower-left corner of the taskbar) and find the GDL 8X Install Tool inside the Garmin list on your start menu.
You can also type "GDL" in the Search Windows area next to the start menu button to find and launch it quickly.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 12-26-2019, 07:56 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
That?s why some of us stick with Macs...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 12-26-2019, 08:25 AM
Thanks, working now...I'm still using Windows 7 so had to find the Garmin folder to launch it
