I used Van's FWF kit which included the Lord mounts and bolts. Assuming these are the same bolts Van's sells separately, then you should be good to go. Be sure to order the proper Lord mounts for your engine and engine mount. The FWF kit is a good value, and you can delete what you don't need.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Reason: Add
