Old 07-04-2019, 01:26 PM
JnTTurner JnTTurner is offline
Default RV 14A Brake Line Leaking
I have about 215 hours on my 14A and have had to replace the right brake line twice and the left line once. Each time the leak has been from the brake line flare at the top of the landing gear strut. Has anyone with a 14 had this problem? Thanks. Jim
Old 07-04-2019, 01:33 PM
Three failures suggests a systematic problem.
Are you using the correct (aviation, not auto) flare tool? They are not the same.
All the correct parts, including the correct size sleve?
Old 07-04-2019, 01:40 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Also are you using the Beringer brakes, stock kit brakes, and what fluid?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
