Old 04-25-2007, 07:09 PM
gmpaul gmpaul is offline
Default Thermocouple connectors
Today I drilled a hole in my firewall for my wiring. Added a split o-ring and started poking the wire through. All I need to do now is add some extension wire. This is when I had a Brain Cramp!
Wouldn't it be a clean installation to use a military bulkhead connector? You know the 12-pin with J and K pins for temps.
I Googled up connectors and the prices weren't bad until you add type J & K pins. Then Oh My Gosh...the prices are out of site!
Here's my question: What did everybody else use for thermocouple connectors?
Thanks in advance,
GP
Old 04-26-2007, 03:39 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Well I may be missing it.....but
Originally Posted by gmpaul
Wouldn't it be a clean installation to use a military bulkhead connector? You know the 12-pin with J and K pins for temps. I Googled up connectors and the prices weren't bad until you add type J & K pins. Then Oh My Gosh...the prices are out of site!
Paul what J & K pin? Do you mean J and K junction thermocouple for CHT and EGT (respectively)? What does that have to do with a bulkhead connector? I think I got it. My answer (opinion) is a firm don't.
Why are you making more work, effort and cost. Are you going to remove your engine or tear your plane down every other week? What do you gain by doing this? Will your gauge work properly with a connector in the extension wires for the EGT/CHT? The answer may be NO.
When you run the wires, consider they will be there for the rest of your life or the life of the plane. There is no reason to make a service connection for the EGT or CHT. Think LIGHT WEIGHT, LOW COST and SIMPLE. Buying expensive mil-spec plugs does not really meet these criteria. Again I ask why? It look cool?
Here's my question: What did everybody else use for thermocouple connectors? Thanks in advance,GP
I get in trouble trying to answer questions I don't have all the info on, so I may be missing something; if so sorry.
What thermocouple connector does everyone else use? Usually the one that came with the gauge. CHT or EGT probes, probe extension wire and the gauge are a matched set.
Thermocouples (probes) and their extension wires or junctions fall under a SPECIAL kind of wiring. It usually is a MATCHED set with the gauge / instrument. In some cases (most), it requires careful attention to the instructions the gauge and probe came with. If you need to extend the probe wire sometimes plan wire can be used, other times you need special K or J junction extension wire. The manufactures instructions can tell you this.
Hope that helps, if not may be some one else will be able to help, or may be you can say what kind, model and brand of gauge you are talking about, CHT or EGT and what you are trying to do. From what I gather I WOULD NOT introduce extra "service plugs" or bulkhead plugs in the wires.
Lets say its OK to cut wire to and from a thermal couple (EGT/CHT probe) and you could put a big Mil-Spec plug break in the firewall for example. What would that do for your REALLY?
Good luck.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 04-26-2007, 04:16 PM
aadamson's Avatar
aadamson aadamson is offline
After talking with EIS, EI, and other engine monitor companies, it seems there is little if any specific requirements. J or K thermocouples can be connected to just about any type of connector. However, the requirement is to use thermocouple wire (usually solid conductor), and *never* solder them.
With that said, some thermocouples use a "grounded" type connector. If you have those kinds, they are *extremely* sensative to what type of wire, the lenght of it, etc. However, with that said, I know of no engine monitor system that uses a grounded connector.
In my install (and most of the Lancairs flying), the thermocouples have RMS connectors that are used to take the wiring thru the firewall, these are metal, fireproof CPC type connectors in high density. Also, in my installation, I'm going to use the "Omega" type 2 pin connectors for each CHT and EGT probe. These can be had in either regular temp or ceramic for high temp environments. Cessna uses the regular temp ones on all their new airplanes, however the price difference was only about .20 to go to the ceramic, so I went that way.
Here's what they look like from my 182T
I don't have the web address handy, but if you google omega and thermocouple, I'm sure you'll find them. They do sell on the web and direct too.
These 2 pin connectors as just used to make removal or replacement easy and usually go about 4-6" away from the probe, or where ever the metal spring ends on some probes.
Hope this helps.
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
Old 04-26-2007, 05:08 PM
Default I just drilled holes and fed them through
I installed the EI 4 probe EGT and CHT gauges and used the wiring they supplied. In this system there are three wire segments for each element of the thermocouple pair the initial thermocouple metal half segment, an extension segment and a segment at the instrument. The three segments are interconnected with identical insulated male blade and female rolled edge terminals. The interface is reversed on each pair so the user is unable to cross wire the thermocouple probe half to the wrong instrument input. The company cautions you not to reterminate the wires unless it is necessary and to stow the excess behind the instrument panel. Obviously they do not want you to install a bulkhead connector interface in the wire run. The conductors are solid (not stranded) silver colored metal but I do not know the content (probable one whose resistance is not sensitive to temperature and is not a good thermal conductor) - I suspect the all of the wire in the segments except the dissimilar metal in the thermocouple segment is the same - I know the terminals are identical. The Alcor single probe EGT was similarly segmented but the interfaces were small standard looking "ring" terminals overlapped and fastened together with small (#4 probably) screws and nuts. The point is to make the circuit interfaces rock solid with as low and invariable resistance as possible so as not to drop or vary the the small voltage produced by the thermocouple across the instrument. I drilled holes in the firewall put a rubber gromet on the wires, inserted it into the firewall hole and sealed with Dow 736 hi-temp RTV.
Bob Axsom
Last edited by Bob Axsom : 04-27-2007 at 12:43 AM. Reason: correctly name Gromet instead of "O" ring adn clarify
Old 04-26-2007, 08:59 PM
Thanks again Guys,
I'm sorry that I did not give enough infomation. My egt and cht probes came in a kit frome GRT. They were about 10 to 12 inches too short. I should have specified a length when ordering but I did not know at the time. I called Grand Rapids and they told me to just go ahead and use a standard terminal block with thermocouple extention wires. The difference in the reading wouldn't be much. This answer still bothered me so I called (my guru) Mell, and he confirmed their answer.
Alan, thanks for the picture, I'll probably go that way.
Old 04-27-2007, 12:18 AM
az_gila's Avatar
az_gila az_gila is offline
GP.. the important thing is to use the same materials in each lead for each pair of wires.
Each dissimilar metal to metal joint will create it's own little thermocouple.... if you have the same joints in each lead, these unwanted thermocouples will cancel each other out...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-30-2007, 07:43 PM
jrvssgl jrvssgl is offline
Default Thermocoupler wire.
i too am at the stage of wiring my cht's and egt's for my Odyssee install from MGL Avionics. The egt's have about 3 feet of wire on them whereas the cht's only have about 6 inches. I was planning on placing the RDAC X on the instrument subpanel as to keep it out of the elements and heat as much as possible, so even the egt leads will not be long enuf. After talking to MGL they said icould use pretty much any twisted copper wire of 18 or 20 gauge as extension. However after reading this thread I am certainly confused on if this is actually the proper way to procede. And of course it is Friday evening!!
Does anyone know how much error could actually be produced usingf regular copper wire? A very small difference would not be so bad, but say over 25 degree error would be.
Thank you.
jarvis
Old 11-30-2007, 08:49 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default Omega
Here is a link to some tech info on thermocouples by Omega. Check out the sections on extension wire vs thermocouple wire and "cold junction compensation" for a discussion of what happens when dissimilar metals are used.
They'll also send you a CD with all of their catalogs and applications tutorials etc por nada.
http://www.omega.com/temperature/Z/zsection.asp
Have fun!
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
Old 11-30-2007, 10:18 PM
craigvince's Avatar
craigvince craigvince is offline
Default MGL RDAC-X
Thank you.
jarvis
FYI- The RDACs from MGL are built to withstand the harsh conditions of living in the engine compartment. The biggest advantage to this is it eliminates a bunch of wiring through the firewall to you panel. I don't know about you, but I've got enough wires behind my panel....
Old 11-30-2007, 11:20 PM
i agree it would be a nicer install on the front of the firewall, as far as wiring concerns go, but to me the rdac does not look all that robust. It is not a sealed unit either. Are you going to build it into some kind of an enclosure or just leave it hangin out? Even in the engine compartment the leads will still have to be extended.
