Old 04-25-2007, 04:46 PM
skidmk skidmk is offline
Red face newbie wiring question
Okay,,, looking through the aeroelectic book and cannot find an answer to my question.
mil spec wire.... number 22759/16-14 is this a 14 or a 16? I have others that are just 22759/16-16 ? /18-16 etc etc. is the last number the awg or is it the first?
thanks
Mike
Mike Bourget
Ottawa, Ontario
Old 04-25-2007, 04:56 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Last number is gauge
thanks
Mike
The "slash" on the part number is the "sub-type" for want of a better word....
The last number is the gauge.
So the number {22759/16-14} you give is /16 (the usual aircraft stuff) that is 14 gauge.
...hope this helps....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-25-2007, 05:07 PM
SteinAir SteinAir is offline
Gil is spot on. What is printed on the wire is actually:
M22759/16-XX-Y
Where XX is the AWG and Y is the color code (0-9)
There are a whole host of other numbers that can be added or modified for each mil spec for a whole myriad of minute changes, but the stadard aircraft wire is /16.
Stein.
Old 04-25-2007, 05:39 PM
GAHco's Avatar
GAHco GAHco is offline
Default Wire
The most common type of aircraft wire codes/part #'s can be viewed and saved to your computer for future reference here.
http://www.gen-aircraft-hardware.com...s/pdf/wire.pdf
Please note small correction, the 22 gauge is 3.68#'s per 1,000 ft
I will try to get that fixed.
There are a lot more specs than this, but this will cover most everything on an RV
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 04-25-2007, 06:19 PM
thanks all.....
M
Mike Bourget
Ottawa, Ontario
Old 04-26-2007, 09:21 AM
MCA's Avatar
MCA MCA is offline
Default Guides...
Mike, take a look in the How-To Guides section on our documentation page. There is a lot of generic information that should be helpful to you whether or not you are installing our product.
http://www.verticalpower.com/documents.html
Marc
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 04-27-2007, 06:36 AM
Thumbs up
Thanks Marc,,,
lovely stuff you have,,, hopefully this will fit in my budget.
M
Mike Bourget
Ottawa, Ontario
Old 04-27-2007, 09:38 AM
GAHco's Avatar
Default Fixed
All better now.
Thanks for the help Jonathan.
Get em in the Sky!
Tom Brink Pres.
Old 04-27-2007, 09:40 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Yep, sure was.
I am in the middle of doing the wiring now, printed off a couple of pages to take out to the project.
Thanks.
Mike
