I'm selling my Catto 3B prop along with all of the accessories. I purchased a new Hartzell Constant Speed from Vans. This prop is as is removed from my RV7. Its 66in diameter by 72" pitch. Engn 180HP Design RPM 2750. Red Line Max RPM 3000. I purchased it new in 2015 and have all receipts. First flight was November 2017. It's TT is 150 Hrs. Items in order of installation: Sabre 2.25 Prop Extension, aft bulkhead, Prop, Aluminum Crush plate, fwd bulkhead, 22lb steel crush plate (from Sabre Mfg), spinner. The 22lb crush plate was used to shift the CG fwd. The prop only weighs 17 lbs. Its a bolt on ready to fly setup for any Vans with 180HP. Im Located at KPFR, Fort Pierce, FL. Asking $4000. My email: robert dot belgau at gmail dot com.
Photos:
https://photos.app.goo.gl/8dXQsucBDVVVpEt2A
