Sounds to me like you've got a ground loop Jon. It could be many different things, but a quick one to check is to make sure that your headset jacks are isolated - not grounded - where they are attached. In general, audio line shields should only be grounded at the audio panel end, and you can get this whine if they are grounded at both ends. There are special fiber washers with a little shoulder to mount the jacks.
That's easy to check, and if it's not that....you'll be hunting ground loops for awhile!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
