The new owner must have condition inspections, maintenance and repairs signed off by an Airframe and Powerplant certificate holder, or by the holder of the Repairman?s Certificate.
I'm sure this is true, and I assume the first statement to be true as well.
Your experimental aircraft requires annual condition inspections just like a certified aircraft, except they don't need to be done by an AI. Any A&P is permitted to do them, or the person with the "Repairman Certificate", which can only be the one who built the aircraft, and if he/she applied for and received the certificate. However, you, the owner are permitted to repair any squawks as a result of that inspection.
I don't know for sure, but I always assumed you needed an aircraft manual as well.
