  #11
Old 06-19-2019, 06:27 PM
219PB 219PB is offline
Just to clarify, if one does a good job of baffling, they should not need this option? I am getting close to my first engine start, FAA inspection, paint shop date, etc. Don?t need another project. I installed a pressure plenum and everything else stock, hoping that it would be sufficient.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 06-19-2019, 06:28 PM
greghughespdx's Avatar
You'd really only want/need to install these if, after flying and optimizing baffle seals etc., you find you need them.
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 06-19-2019, 06:32 PM
Bruce's Avatar
Bruce Bruce is offline
Same here.
Scott, curiosity questions please. Assuming our intrepid owner is forced to fly with crappy baffling and too much timing advance...
(1) Why not just remove the core, make the 4 ply 9-oz layup, and cut the slots, skipping the metal louver?
(2) Or, why not enlarge the standard exit? A simple 45 degree cut increases exit area by 41%. Costs nothing and can be done in 15 minutes.
Dan,
Good point.
Did #2 and made all the difference after I installed louvers. Should of opened exit first.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 06-19-2019, 07:20 PM
wsquare wsquare is offline
Default How to open outlet
Does anyone have pictures, or drawing of the ?45 degree? cut that is mentioned? Unclear on how this is implemented.
Wayne
N1179J. Purchased flying.
2019 donation.
Old 06-19-2019, 09:07 PM
Wayne
2019 donation.
I would also like to see some pictures to better understand how the cut would impact the interface with the center bottom support on the A models. Would a half-round cut on the sides of the exit be effective? That would prevent changing the center support. Maybe some kind of scalloped edge?
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-20-2019, 05:29 AM
Bruce's Avatar
I will look on this sight. There are pics somewhere.
I cut mine about 1 inch down and then toward the front of the exit.
Both sides, then open up about 2 inches and then reglass.
With the A model it opens it up as Dan said ~41%.
Boomer
Kathy (KAT) Pauley
See you in OSHKOSH
Old 06-20-2019, 05:40 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default +1 for some pictures
I would also like to see some pictures of the cowl mod
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 06-20-2019, 05:55 AM
DanH's Avatar
DanH DanH is offline
Yes, you would need to modify and/or eliminate the A-model brackets. What do they support?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-20-2019, 06:12 AM
Bruce's Avatar
Thanks for pic Dan.
Found the old thread but no pics.
Dans way is great if you don?t want to extend bracket.
On mine I made the cut at second piece of yarn, forward ~12 inches
Pulled it down 2.5 inches and reglasses.
Extended the brace.
If you take off the gear leg fairing it will slide down and rebuild brace.
I did have a Vettermans 4 pipe and it was real tight.
Look at RV-8 OR TD and you will see the exit difference.
Boomer
Kathy (KAT) Pauley
See you in OSHKOSH
Old 06-20-2019, 06:28 AM
DanH's Avatar
The OP-58 kit may require less fabrication on an A-model. I realize some owners are not builders.
Dan Horton
RV-8 SS
Barrett IO-390
