  #11
Old 06-17-2019, 03:27 PM
airguy's Avatar
airguy airguy is offline
Pull string in a couple of those conduits, to install more wires later. Weed eater string works well and won't corrode.
Old 06-17-2019, 04:21 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by sglynn View Post
I put 2 inch foam from Aircraft Spruce under my floor panels. Why? Perhaps the will absorb sound or keep aluminum from vibrating a bit. Or maybe help with temperature. It is cheap and seemed like the thing to do. I didn't glue it, I cut it slightly large and squeezed it in.
It might also absorb/trap water and cause corrosion.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
