Old 04-24-2007, 07:40 AM
pierre smith's Avatar
Default Shortening oil filler tube??
Hi guys,
My buddy needs a shorter oil filler tube for his -4. Have any of you shortened the oil filler tube and the dipstick (Lyco calls it a "gauge"). How did you do it? Use PVC tubing? Reason is that Lyco wants $175 for just the tube.........there's gotta be a simple fix......
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-24-2007, 07:53 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default I want a longer one
Oil filler tube/dipstick that is. Maybe a swap is a better option.
ronlee @ pcisys dot net
Old 04-24-2007, 09:11 AM
Default Length?
Hi Ron,
The tube is 11 1/2" long (not counting threads) with the matching dipstick. We need ten inches or less. Whatcha got?
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 04-24-2007, 01:14 PM
ABRV4 ABRV4 is offline
Default Filler Tube
I just took mine to a local machine shop and had them remove a center section about 2" long and then reweld the two pieces together. After paint it looked great. I then took a hacksaw to the dipstick and removed a section from the end. The old level marks were deleted using a file. I'll remark the stick once I get the plane ready to fly - hopefully this summer. It cost me a total of $15.
Alan
RV-4 N7028K
Old 04-24-2007, 01:26 PM
godspeed's Avatar
godspeed godspeed is offline
Default trade ?
I have one that I need to trade.. my rv9a needs the longer tube and gauge
check your private mail on here.. the one I have is metal not plastic..
I did buy the longer tube , but the treads are not the same..
Old 04-24-2007, 01:31 PM
Default It's plastic
Alan
RV-4 N7028K
Hi Alan,
This one's plastic or something similar. We thought about cutting it and using a PVC coupling but the heat and vibration was a concern.
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 04-24-2007, 04:01 PM
tin man tin man is offline
Mine was plastic or something also. I cut at the dip stick end and glued back together with 2216. Cut and recalibrated dipstick. No problems 10 years/1000hours later.
Tom
Old 04-25-2007, 07:03 AM
Default 2216?
Thanks Tinman,
What is 2216 and where is it sold?
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 04-25-2007, 07:19 AM
DEKECMYRV DEKECMYRV is offline
Default oIL FILLER TUBE
I JUST CUT A SECTION OUT AND THEN SPLICED IT BACK TOGETHER WITH A SHORT PIECE OF AILERON CONTROL TUBE & GAVE IT COUPLE OF WRAPS OF FIBERGLASS. 8 YEARS NOT A ISSUE.
Old 04-25-2007, 09:39 AM
Red Voodoo's Avatar
Red Voodoo Red Voodoo is offline
Default 2216...I know this one!
Better known as Scotch-weld. Aircraft Spruce has it:
http://www.aircraftspruce.com/catalo...hesive2216.php
Ben Ridgdill
VAF #1497
RV-9A Kit #90217 Sold;
Scrounging RV-3 parts
RV-9 Tail Kit #91415 on Deck
\_____@(")@_____/
I love it when a plane comes together!
