Old 06-12-2019, 05:27 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Lycoming case bolt torque ?
Installing SDS dual sensor on 0360. The sensor bracket uses 3/8 bolts on the front main. Lycoming book says 30 ftlb. On line no help to confirm, so is 30 correct ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 06-12-2019, 05:46 PM
N804RV's Avatar
N804RV N804RV is offline
I believe those are 25ft/lbs. Service Instruction 1029D (8/15/86) is the most current.
https://www.lycoming.com/sites/defau...s%20and%20.pdf
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 06-12-2019, 06:33 PM
Default 25 ftlb
Thanks much Ken 👍
Larry DeCamp
Clinton, IN
