Old 06-11-2019, 07:05 PM
SteveL SteveL is offline
Default Pics with SmugMug/MAC
Good evening,
I can get the URL info on to the thread but unable to get view the picture. Any ideas?
SteveL
Old 06-11-2019, 07:31 PM
KRviator's Avatar
KRviator KRviator is offline
Can you upload the URL you're referring to, so folks could help?
I'm assuming you're not a neophyte with hosting images, but if you are, you need to embed the *.JPG string between the BBcode IMG tags.
For example:
This URL: https://live.staticflickr.com/7901/4...0b23b56f_c.jpg, when placed between the {IMG} {/IMG} tags (though with square brackets), gives the below photo.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 06-11-2019, 07:46 PM
Draker's Avatar
Draker Draker is offline
I use Smugmug for all my RV-7 picture posting to VAF. Make sure, after you click the "share" icon, look for where it says "Choose a size" and choose one. I usually go with "Large". The resulting link displayed in the box below should end in .jpg, which is what you want to use here.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
Old 06-11-2019, 08:18 PM
Thanks Draker,
I can get to the green box that you have in your pic. What do I do with it then?
Thanks, Steve
Old 06-11-2019, 08:24 PM
KRviator's Avatar
Originally Posted by SteveL View Post
Thanks Draker,
Thanks, Steve
You'll need to copy-and-paste (Ctrl-C / Ctrl-V) that URL between two "IMG" tags when typing, or when composing a post you can click on the photo icon above the text-entry box, and paste the URL string into that and the forum will automatically include the IMG tags for you.
With BBCode (the stuff that runs DR's forums for him), "tags" are things that alter what you've typed into bold text, italicised, hyperlinks or photos. They are used by enclosing them between [] brackets such as:
[image] <your fancy URL address> [/image]
would in turn embed your photo into your post if you used 'IMG' instead of the word image.
Old 06-11-2019, 08:26 PM
wjb's Avatar
wjb wjb is offline
Copy the URL in the green box, and then paste it into a post between
[img] ..url.. [/img] and you're good to go ...
For example: (for url https://photos.smugmug.com/photos/i-...-srKzMfP-L.jpg)
Bill Bencze
Old 06-12-2019, 07:34 AM
BH1166 BH1166 is offline
Thanks Draker,
Thanks, Steve
Ok this works for me every time. In smugmug do as Draker did BUT after picking size next click the box BBCODE. COPY the code that shows up in the box by whatever means you like ( highlight hover over copy with apple iOS or control c if highlighted with windows) . After copying of code go to your post on VAF and put cursor where to insert. Then click on fifth icon from right..looks like a box with mountain and sun in it....another box will open up .....remove the http code in the box and do a paste.....your code from smugmug will go into the box ....ENTER ....now do a preview a nd your pic should be there.
Butch
RV6A Purchased N72TX
2020 Dues Paid
