Old 06-29-2019, 07:30 PM
9GT's Avatar
9GT 9GT is offline
Originally Posted by Bob Martin View Post
What Mel said......Tks Mel.
Clearly I made up the bad connector, The only differance was I crimped the original/bad.....and I soldered the replacement/good. Very hard to take one apart after assembly, so I will never know for sure why it was bad.
Lesson for me is that if I check the connector right after I assemble it I will know right then and fix it......instead of "assuming" it was good and causing lots of troubleshooting.
Thanks again for everyone's input. Still learning!
Steinair has a good video on installing BNC connectors and testing before you crimp. I was installing a lot of RG400 with BNC & TNC connectors a few weeks ago on my project and one of the BNC connectors failed the continuity test before I crimped. It was a single strand of untrimmed shield that was the culprit and I missed seeing it when I was assembling the fitting.
David C.
Howell, MI
