Old 06-06-2019, 11:53 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Manual Trim Issue
Yesterday when approaching to land I pulled power back and started running my manual trim nose up to trim for approach speed but I never got the speed change I expected. I ran it all the way out and had to hold back pressure for the landing. I was ready to do a go around if needed but the landing worked out fine. I wish I had left the trim tab where it was so I could look at it after landing but I did not.
After parking the plane I got a little help from a local mechanic and we cycled the trim full up to full down and then did it with a little pressure on the tab and everything worked fine.
The mechanic mentioned that some manual trim systems include a clutch in them that can slip so that the pilot thinks he is moving the trim tab but is just turning the knob. He does not know RVs.
Hence my posting to the forum. Has anyone else had a similar experience?
BTW I am in Talkeetna, AK today. Am doing my bucket list flying vacation from Texas through Alberta, BC, the Yukon and into Alaska. Very interesting, tremendously beautiful, but with challenging weather. Definitely not Texas "severe clear" flying.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 06-06-2019, 12:52 PM
noelf noelf is offline
What was your gross landing weight and CG?
Noel
RV-6A N6NF
tip-up
flying
Old 06-06-2019, 12:53 PM
Bubblehead's Avatar
More info - I was the only person in the plane, I had about 30 lbs in the front baggage compartment and nothing in the back. ForeFlight wt and bal showed I was still in the envelope but on the nose-heavy side. Maybe I just don't have enough trim authority at fwd cgs and need to move stuff behind the back seat.
Old 06-06-2019, 12:59 PM
Bubblehead's Avatar
about 1405 lbs and 79.9 in
Old 06-06-2019, 01:49 PM
fl-mike's Avatar
fl-mike fl-mike is offline
no clutch on the RV manual trim system.
you probably just ran out of trim. Not uncommon with forward CG 8's.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 06-06-2019, 02:36 PM
Bubblehead's Avatar
Thanks Mike. The more I think about it the more I think you are right. I rarely fly without traveling bags and stuff in the back, or a passenger, and on this trip I have extra tie-down material in the front baggage compartment. I am within the cg envelope but ran out of trim.
BTW I now have 998.8 hrs flying this RV and tomorrow will go over the 1000 hours mark. The plane has more - I am the 4th owner and have had it for 11 years.
Old 06-06-2019, 04:34 PM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
Look at the base of your trim control knob. There is a nut on the cable housing that screws to the base of the trim control knob. Make sure it?s tight. Before I converted from manual trim to electric trim I had that cable nut become loose and then off the trim control knob (twice). If it happens in flight you?ve got your hands full of aircraft, but it?s still controllable. However, it?s feels strange to release stick pressures to land.
Had that happen which is one of the reasons I converted to electric trim. I love my electric trim system!
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 06-06-2019, 04:42 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Solo I always put my tiedowns, oil, tools and any luggage in the back for better CG. In your configuration I would run out of trim but my knob will stop turning.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 06-07-2019, 01:16 AM
Yen Yen is offline
You will get better fuel economy with the G of G aft, rather than forward. The only reason to have weight forward is if you are getting too close to the aft C of G.
Old 06-07-2019, 09:25 AM
Bubblehead's Avatar
I gave this a lot of thought and I am sure the problem is that I had nothing in the back and more than normal stuff (tie down, oil, some tools) in the front. I appreciate all the information. It is very rare for me to be solo in the plane without luggage etc. in the back that I guess I never had the cg that far forward!.
TankerPilot 75 - I will check that nut too.
