Old 06-04-2019, 06:07 PM
MiserBird's Avatar
MiserBird MiserBird is offline
Default Green color in center of exhaust valve
Doing a borescope inspection on my O320E2A with 188 hour low compression ECI cylinders and found the exhaust valves to be almost too
clean with a green dot in the center of some.
I have read that green is not good, but the location seems strange to me. I cruise at around 50% power, 325 CHT, 50deg ROP, 5.5 GPH ( by tach
time) 18in hg around 2200 RPM. One PMag 32 deg max on NGK BR8EIX's , one Slick on Tempest UREM37BY's. The plugs were white, with heavier light color deposits in the UREM37BY's than the very clean NGK's.
It has been said that it's difficult to damage a Lycoming at less than 65% power, but I'm beginning to wonder if I need to change any settings.
FWIW, the engine runs perfectly, and will idle down to 600 RPM on the EMag alone, with a Catto prop.
Thanks in advance for any insight, and advice.
Dave McKinnon
KAJR - Cornelia, GA
1975 Cardinal RG N1593H since Mar 1993
1980 RV-3 N3VR Bought flying Sept 2017
Dues current 2021
Last edited by MiserBird : 06-04-2019 at 08:36 PM. Reason: trying to get pics full size
Old 06-04-2019, 11:01 PM
lr172 lr172 is online now
exhaust valve stem is sodium filled and acts as a heat sink. Therefore the area with the green dot (center, where the sodium filled cavity ends) will be cooler than the balance of the valve face. Not surprising that this could account for different deposit types or rates. Deposit type and color is often dictated by temperature at the deposited surface. Notice different deposits on exh valve vs intake valve vs cyl crown, etc. All are at different temps.
The green color wouldn't concern me in the slightest. Different fuel additives also account for different colored deposits.
Larry
Old 06-05-2019, 06:45 AM
rocketbob's Avatar
Sulfur deposits...normal.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-05-2019, 07:43 AM
Walt's Avatar
Walt Walt is offline
The bright white color and super clean valves generally means high combustion temps.
If the plugs are bright white instead of the normal tan color I would be looking at low fuel flow.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 06-05-2019, 08:02 AM
bpattonsoa's Avatar
bpattonsoa bpattonsoa is offline
Great borescope. What brand and model is it?
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '89 (Sold)
HP-18 5596S flying since '83
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 06-05-2019, 11:58 AM
MiserBird's Avatar
Thanks for your responses. I'm going to enrich the mixture to around 100 deg ROP and take a look again.
The borescope used is a Vividia VA-400.
Dave McKinnon
KAJR - Cornelia, GA
Dues current 2021
Old 06-06-2019, 07:55 AM
Boyd Birchler Boyd Birchler is offline
At such a low power setting I would go to peak on the leanest cylinder. The engine is running too cold! The higher EGT would help to keep from sticking a valve caused by combustion deposits. Lycoming says you can run peak EGT at any power setting below 75%. My personal preference would be below 65%.
Old 06-07-2019, 01:22 AM
Yen Yen is offline
Why are you running rich of peak. I thought the object would be to get max power from min fuel and to do that you run lean of peak.
Old 06-07-2019, 02:33 AM
Hartstoc's Avatar
Hartstoc Hartstoc is offline
100 degrees ROP corresponds to max power, max CHT?s, max stress and strain, max wear and tear, min economy, min longevity. Not a good place to spend much time!
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Frmr Test Pilot/Author CAFE APR's:
RV-8A, S-7C, Europa, Glastar.
-2021 VAF donation!!-
"RV-Fun is inversely proportional to RV-Weight!"
Old 06-07-2019, 05:55 AM
RV6_flyer's Avatar
Max power is ROP. Cannot make power without fuel. As fuel flow is lowered, the engine will start running lean of peak (LOP) producing less power. Less food (fuel), less horsepower.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
