Related to the topic, I made a little database of empty weights for RV's completed in the last year or so. Total non-scientific, but somewhat interesting. No surprises, avg empty wt are heavier than Van's specified range/ recommendation. Although some builders have achieved lower weights than Van's spec. There is no accounting for paint, fairings, and interior.
The avg wt for all (115) RV's = 1075lbs. The RV-6A was the highest over average. The lightest Avg was a RV-4 @ 94lbs under.
BUILDER EMPTY WEIGHT
Model; count; MIN; MAX; AVG; Delta-from-avg
RV-4..; 11; ....874; 1107; 980; -94
RV-6..; 28; ....980; 1244; 1058; -17
RV-6A; 22; ....990; 1195; 1105; 30
RV-7..; 15; ...1011; 1141; 1073; -2
RV-7A; 10; ...1020; 1134; 1092; 18
RV-8..; 15; ...1035; 1178; 1102; 27
RV-8A; 07; ...1032; 1165; 1101; 26
RV-9A; 07; ...1034; 1168; 1086; 12
AVG = 1074.6 lbs
The actual builder weight Vs. Van's "Spec" empty weight. Positive Delta means over Van's spec, Neg # indicates a lighter weight than Van's spec. The lightest weight was a RV-7A, 57 lbs below Van's Min spec.
The fattest was a RV-6 @ 226lbs over max (recommended) empty weight.
VAN'S DATA vs. BUILDER EMPTY WEIGHT
----------Vans--------Vans-----
Model; ...Min; Delta; Max; Delta
RV-4...; ..905;..-31;..913;..194
*RV-6.; ..965;..15;..1018;..226
*RV-6A; ..985;..05;..1038;..157
RV-7...; 1061;..-50;..1114;..27
RV-7A.; 1077;..-57;..1130;..04
RV-8...; 1067;..-32;..1120;..58
RV-8A.; 1067;..-35;..1120;..45
RV-9A.; 1028;.. 06;..1075;..93
DELTA= VANS (MAX)/(MIN) to Actual (MAX)/(MIN) Wt. Difference
DELTA (Pos) = Builders Min/Max greater thanVANS Spec.
* Van does not publish range so I used 53lb range, like RV-7/-8
Light RV-4: 905-31= 874lb; Fat RV-6: 1018+226= 1244lb
The last table breaks weight down by eng or prop or both. The Heavy wt was an IO360/CS prop at 1244lbs (RV-6). The light wt had a 320/fixed, 874lbs(RV-4). No shock here. However the diff between max (RV-8) & min (RV-4) is 370lbs, albeit diff models, the airfoil is the same NACA23013.5 w/ wing area of 110 vs 116 sq ft. A light RV-4 is a kick. Someone asked Mr. Van what his favorite RV was, RV-4,-6,-7,-8. His reply RV-3. Go figure. Several auto conversions, Subie, Rotary not included were on the high side, equiv to IO-360 (200HP)/CS prop. It is obvious eng/prop choice affects weight. However it will give you an idea how you stack up. Most popular combo of group: O-320/Fix or O-360/CS, RV-6 (for the 115 RV's I looked at).
EMPTY WEIGHT BY PROP, ENG or ENG/PROP
Total; Eng/Prop; MIN; MAX; AVG
60; FIX;..........874; 1170; 1041
55; CS;.........1010; 1244; 1111
41; 320;..........874; 1168; 1034
60; 360;..........986; 1189; 1084
14; IO360;.....1103; 1244; 1151
32; 320/Fix;......874; 1106; 1019
28; 360/Fix;.....986; 1170; 1066
09; 320/CS;....1010; 1168; 1084
32; 360/CS;....1026; 1189; 1101
14; IO360/CS;.1103; 1244; 1151
Fix or CS= no breakdown of brand, blade material, most popular=Sensenich&Hartzell
320= 150 or 160HP Carb or injected.
360= 180 HP Carb or Injected
IO360= (200HP)
My 2cents, less weight= less lift req, less lift = less drag, less drag = less thrust req, less fuel burn. This also means more useful load, more range, lower stall speed and better climb.
(Subjective) I like the feel of a lighter RV. I have flown RV's with both heavy and light empty weights, the lighter one has a better feel on the controls. If you have flown differnt RV's you know what I mean. If you only do S&L cruz-ing OK, weight is less an issue, but if you like the aerobatics, dog-fight and short field capability, weight affects these charicteristics.
If you want full tilt IFR Bells-N-Whistle, 200HP, CS prop, full interior & paint, it will weigh more and you will sacrafice something. Nothing wrong with the choice of making a Caddy but don't expect it to be a sportscar to. No need to justify choices, just be aware of the trade offs. Van wrote many RVator articles in the last 10-15 years that address the topic of weight and RV's.
I think the paint weight of less than 10lbs is the bottom range, I have read of 20lbs or more (30lbs), plus you have to add all the internal priming/painting. As someone suggested, ask yourself do you really need it? Can you add it later if you find you can't live without it? What-ever you do, it adds weight, cost and build time.
Cheers RV-4, RV-7(project)
