Acknowledging that Aircraft do not turn on a dime and that some finite distance is travelled around a turn which is in addition to the point-to-point distance between any three points, the following table will be used to calculate the turn ?allowance? that is to be added to the total point-to-point distance of any Course:
Bank Angle
45
TAS in Kts
180
G- Radius in load Ft
1.41 2877
Turn in Degrees
45 90 120 135 360
ROT Distance traveled */sec NM
6.06 0.37 0.74 0.99 1.11 2.96
Example:
The point-to-point length of a four-turn Course is calculated in a flight-planner to be 100 NM.
The Course is shaped as a square with four 90-degree turns.
The four 90-degree turns are summed to total 360 degrees of turn.
Based on the table, 360 degrees of turn adds 2.96 NM to the Course distance*. The total Course length (to be used in scoring) is 102.96 NM**.
* The standard turn allowance uses 180 knots and 45 degrees of bank as an average of the typical range of Aircraft performance and Pilot experience
** Race Directors may interpolate table distance values as needed based on total degrees (for instance, 180 degrees is not listed, but 360 is given and can be divided by 2).
The above is used for timing.
5-6 turns
Winds etc
Most of my times were same as Vans posted speeds.
200-204 mph
130-150 mile races
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
