Old 05-23-2019, 06:12 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default TOOBUILDER question on plenums ?
There are many comments regarding all the screws required to secure a plenum. Toolbuilder has referenced the use of piano hinge. This is very appealing.
The metal baffle wall component will probably need to curve a little. Is there a better way to curve a hinge than drilling and notching ?
Is there a better way to secure plenum than screws,1/4 turns or piano hinge ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 05-23-2019, 06:27 AM
BillL BillL is offline
I use #6 screws and nut plates spaced a little less than 3". I took a piece of fiberglass and screwed it to a wood block with varied spacing then pressurized the back side to determine the spacing. With a proper screw gun it does not take very long to remove it. It is 10 minutes, not 10 seconds. YMMV
Bill
RV-7
Lord Kelvin:
Old 05-23-2019, 07:32 AM
Clint B Clint B is offline
Hi Larry, I sent you a PM
Old 05-23-2019, 08:11 AM
Toobuilder's Avatar
Concerning the curved hinges - note that only my rear wall is curved (and only the center 1/3). The front walls are straight (just worked out that way on my airplane)
...but no matter, the hinges lie flat anyway so they will follow a curve without modification. The "L" angles (.016 titanium in this case) on the front and back walls stiffen things up a bunch and provide a rudementary seal surface. The stiffness helps when installing the lid as even the relatively short side walls need a bit of "steering" to keep them in line when the hinge pin is sliding home.
Here's another view of the straight plenum end wall. And yes, the inlet is rigidly mounted on the wall. The inlet bell sits in front of the cowl and moves with the engine.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 05-23-2019, 09:17 AM
DanH's Avatar
DanH DanH is offline
Somebody was studying a certain Boomerang shaped airplane....
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-23-2019, 09:35 AM
Toobuilder's Avatar
...well I do live right down the street.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 05-23-2019, 10:56 AM
DanH's Avatar
Always thought that inlet structure could be the optimum for high Vi/Vo, as the diffuser shape be be fixed/perfect, not disturbed by internal couplers and torque misalignment.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-23-2019, 11:37 AM
scsmith scsmith is offline
Definitely an advantage for internal aerodynamics, ease of fabrication and assembly.
A little bit of motor-mount sag and the inlet rings will conspicuously not match the cowl very well.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 05-23-2019, 12:23 PM
Steve, if that happens, given the shape of the cowl in the vicinity and aft, would that have an adverse effect?
I see it as having no effect on engine or oil temperatures, assuming the oil cooler gets its air from the plenum, and having almost a zero change in airplane drag. But you'd have a better idea about that than I would.
Dave
Old 05-23-2019, 02:34 PM
Toobuilder's Avatar
Engine mount sag can be shimmed as required to maintain alignment (just like most of us do to keep the spinner aligned). The degree to which any misalignment gets offensive depends on the treatment directly behind the rings. If you expect it to fair absolutely perfectly and look like one piece, it's going to be a mess. Treat them like two separate pieces and it gets easier. My cowl was built with much bigger rings in mind so I have a bunch of sanding and rework at the transition, but even in rough form it looks pretty good.
One other benefit to rigid inlets is that you can extend them far forward. Mine are breathtakingly close to the TE of the prop, but wont hit no matter how much the engine shakes around.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
