04-22-2007, 10:15 AM
Aileron pushrod jamnuts
Two things about the aileron pushrods I'm uncertain about:
1) On DWG 15 (RV-9/9A), for the pushrods the plans call for AN316-4 and AN316-6 Jamnuts. In my kit, I do not appear to have these nuts. In Wing Bag 1930-2, I have 5 each of AN316-4L and AN316-6L nuts (these are the thinner ones). Am I supposed to use these thinner jamnuts for the pushrods?
2) For the W-918 pushrod, shown on DWG 15, it does not say "Make from...". I assume I am to use the ST-4130-035x1/2x48-PC, and cut this in half, one half for each W-918 pushrod. Is this correct? How should I cut this steel... would be tough on my bandsaw blade?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
04-22-2007, 12:54 PM
Hi guy!
I'm getting close to the same point you are. I would like to know the answer to both questions myself.
I only received one of the small diameter steel rods as well and I was going to measure the distance needed for each and see if cutting it in half would be enough. I'd be willing to be it is.
As for the jamnuts. I used the inventory pic sheets to determine which hardware went where. I found that each bag number had coresponding parts per a "sub assembly" and most all the parts were together. Here again I'll bet you'll use the jamnuts in question.
I'll keep an eye on this one to see how wrong I am.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
04-22-2007, 12:57 PM
The 48" tube cut in half gives 24". The total length should be just over 27". I checked the threaded rods and bearings... when you attach these they can easily make up the remaining length.
So I'm 99.99% certain this is what to do about the rod itself (although still don't know if trying to cut that steel will destroy my bandsaw blade!).
Still don't know about the jamnuts... I've mailed Vans.
Phil
RV9A (SB)
Ottawa, Canada
04-22-2007, 04:43 PM
I have tucked my bandsaw away in a safe place. I no longer wish to try and use it to cut anything. It has never cut a straight line, not with a new blade or what I try to do or adjust. I can get better cuts done quicker with my trusty hacksaw. I'm gonna use it to cut my steel aileron pushtube and everything else metal.
(author unknown)
FLYING since 2018
04-22-2007, 05:01 PM
I just used a tubing cutter. Worked fine.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
04-23-2007, 07:58 AM
A hacksaw works great for cutting the tubes. I have more details here...
http://www.flightinnovations.com/win...ml#Wing%20Misc.
I finally found the jamnuts in a bag of miscellaneous nuts but I'm not sure if they came with the wing kit or the fuselage kit.
04-23-2007, 08:21 AM
Great site Bret!
Phil
RV9A (SB)
Ottawa, Canada
04-23-2007, 02:16 PM
Use the Ls
I love Vans... it took me a while to get used to their very curt, brief and direct manner of responding to support queries, but the brevity is probably how they manage to respond to email questions usually within 1 business day.
I asked about those Jamnuts, and the response was "use the Ls" (the L's being the thinner ones).
Anybody know how tight these jamnuts should be? It seems like thier purpose is to fix the position of the rod-end bearing... not sure if torque values are specified for a jamnut over a rod-end bearing.
Phil
RV9A (SB)
Ottawa, Canada
04-23-2007, 03:13 PM
Opulence, I has it...
Same kind used on aluminum fuel lines, etc.? Didn't think it would do the job...I'll give it a try.
My bandsaw is the tool of last resort as well, for same reason.
Joe
Joe Ferraro
DFW, VAF #17
SOLD
04-23-2007, 04:16 PM
"bandsaw for sale"
I'm finding that my bandsaw is mostly usefull for for cutting the wood parts for leading edge jigs. For aluminum and steel I use a hacksaw or die grinder with a cutting disk then file smooth.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
 RV-9A Firewall Forward
[Engine purchased]
