Old 05-21-2019, 12:07 PM
aguiraf's Avatar
aguiraf aguiraf is offline
Default GI-106 and IFD 440
The GI 106A OBS shows a 25 degree error on a VOR CRS. The GI gets the signal from the IFD440. The OBS on my KX125 shows to be on the money. Has anybody else experienced this error? Or has suggestions
A.F. Aguirre
Old 05-21-2019, 01:15 PM
aguiraf's Avatar
Here is the solution from Avidyne Technical Support:
How to Calibrate an analog OBS on the IFD
The following does not apply to the KI208A or KI209A indicators.
If you get continual messages on the IFD to "Set Course To xxx" and your analog CRS is set correctly, it likely means you need to calibrate your OBS input.
You will need to boot the IFD into Mx mode, and toggle to the "Config" tab. From here you will want to use the lower RH outer (fat) FMS knob to scroll to the "Main CDI/OBS Configuration Page" shown below.
https://desk.zoho.com/DocsDisplay?zg...3def1726286090
https://desk.zoho.com/DocsDisplay?zg...f99d5e6913db9c
A.F. Aguirre
